TwinTurbo.NET: Nissan 300ZX forum - I'd try to fix any boost leaks and go with a good EBC
Barry'z (NJ)
on November 27, 2007 at 11:32 AM
With better turbos, yes you do
posted by Keaner
on November 27, 2007 at 11:27 AM
at this point so he could run a few more PSI and get better use of the injectors he already invested in ;~)
It's a new link
have had my 96TT for 8 years thinking future
vect0rx
11:05:08 11/27/07
depending on ur power goals
Alan(NJ)
11:13:05 11/27/07
Re: depending on ur power goals
vect0rx
11:25:28 11/27/07
Look at sport500s
ben7021
11:34:48 11/27/07
Re: Look at sport500s
vect0rx
11:38:07 11/27/07
You'd get better boost and less lag
Keaner
11:49:57 11/27/07
"Closer to 2000 than 3000"
ben7021
15:49:39 11/27/07
Hmm, I guess it makes sense w/ the downpipes,
Keaner
16:20:34 11/27/07
I had a similar set to the GT600R
Keaner
10:19:01 11/28/07
Why do you consider the 555cc's a bad idea? (n/m)
ZCulture
11:14:20 11/27/07
Re: Why do you consider the 555cc's a bad idea?
vect0rx
11:16:23 11/27/07
Keaner
11:27:37 11/27/07
Re: With better turbos, yes you do
vect0rx
11:29:52 11/27/07
iirc stock turbos hit a wall at 18 psi
Barry'z (NJ)
11:36:12 11/27/07
Re: iirc stock turbos hit a wall at 18 psi
vect0rx
11:39:20 11/27/07
Exactly, and you'll have it if/when you decide you want more (n/m)
Barry'z (NJ)
11:53:02 11/27/07
Ah, then the 555s should hold you for a while.
Keaner
11:38:05 11/27/07
I'd try to fix any boost leaks and go with a good EBC -
Barry'z (NJ)
11:32:19 11/27/07
2nd on both counts (n/m)
vorpalZ
11:49:29 11/27/07
Well, the boosting issue is orthogonal to injectors.
ZCulture
11:35:04 11/27/07
orthogonal, nice word ;~) (n/m)
Barry'z (NJ)
11:43:28 11/27/07
orthogonal • adjective-of or involving right angles; at
240Z FeO2
12:54:16 11/27/07
not in this case, "statistically independent"
fourZero
13:24:45 11/27/07
Really? I think it's a literary use of 'orthogonal' in the
240Z FeO2
15:48:42 11/27/07
Well...
Barry'z (NJ)
16:03:40 11/27/07
That's more like it... See if I rely on the Oxford English
240Z FeO2
19:07:44 11/27/07
1st off all your injectors are 615cc, 2nd there is a reason
11:51:30 11/27/07
Ok, heres a question....
Keaner
11:54:40 11/27/07
He better not make that list coz it'll be a very long one. (n/m)
ZCulture
11:59:05 11/27/07
Exactly my point! (n/m)
Keaner
12:01:28 11/27/07
Newer style "555" injectors actually flow @ 615cc - call JWT
12:52:03 11/27/07
Wow, didnt know that.
Keaner
13:21:20 11/27/07
EBC suggestions?
vect0rx
11:43:00 11/27/07
Blitz SBC-iD
vorpalZ
11:51:32 11/27/07
2nd. :)
MixManMash
12:58:11 11/27/07
:waves: (n/m)
vorpalZ
13:56:18 11/27/07
3rd (n/m)
sfarrah
15:05:46 11/27/07
i would skip on the sport 600's. There
moxie (SF)
12:44:47 11/27/07
What would you recommend?
RICH1
13:39:26 11/27/07
530s, or GT600R, as mentioned above, cheaper and better (n/m)
Keaner
13:49:44 11/27/07
GT600r's are the turbo's I'd like to get when mine die.
Jason300zxTT
15:35:13 11/27/07
